Page 2 of 3
Re: Multiecuscan 3.2 RELEASED!!!
Posted: 14 Aug 2011, 19:30
by basjan
Dear Yani,
I very much appreciate your software and I was happy to see that the latest version also supports the engine ECU for a Alfa 159 3.2.
However, after connecting to the ECU, I can only see the Info and Error screen, but the Paramaters and Actuator screen are not present. Is this part not yet fully functional ?
Regards
Posted: 15 Aug 2011, 10:35
by Juggers2k
basjan wrote:Dear Yani,
Regards
From the Supported Vehicles List:
Bosch Motronic MeD7.6.2 CF4/EOBD Injection (3.2) |INFO|DTC| KL ELM OBDKey
So only ECU information and fault codes available at present.
Posted: 15 Aug 2011, 11:35
by basjan
Juggers2k wrote:basjan wrote:Dear Yani,
Regards
Thanks, a typical case of RTFM
(Although I didn't know I could look up the specific details and capabilities per vehicle)
Posted: 18 Aug 2011, 11:55
by jantimralf
The function Service Reset for Ducato 3,0 JTD is new in version 3.2 (I use ELM 327), but it will not work.
The problem is, that I got the failure notice “False ISO Code” when I use the function.
False ISO Code: 32 83 23 85 32
When I do the scan of the whole system, than it shows for Instrument Panel (Armaturen) :unknown/unsupported
Solution found!!! Search the theme: Problems with Ducato 3,0 DPF Service Reset
Posted: 29 Aug 2011, 10:26
by alfa156sarajevo
There is another bug in this version of FES software...
Again problem with Service Interval Reset!
I CAN DO the service coupon, BUT I CAN NOT do the:
- “Set the date until next service interval”
- “Set the km until next service interval”
I did not have any luck with this!
Tested on a Fiat Punto 2003 1,9JTD (new MY '03)!!!
Posted: 30 Aug 2011, 17:10
by Ruudje
Hello Yani,
Love the software really do! I started working with it this year en I helped me and the Dutch Fiat Bravo/a Marea club alot.
But theire is one engine that I cannot read atm and a lot of our forum users have this ECU. It's the bravo/a marea delta 1.6 16V (IAW 1AF).
Is theire a possibility that you can add this ECU so I can make a lot of people happy?
All the other engines don't give a problem but this is a very common engine here, hope you can help!
Thanks in advance, Best regards Ruud van der Horst The Netherlands
Posted: 01 Sep 2011, 21:46
by gyalog_kakkuk
Hello Yani
Expected to be included in key (remote key) program function?
Krisztian
Posted: 06 Sep 2011, 18:11
by Joolri
I have registered version FES 3.2
My car is Stilo 1.6. 2003
When I connect engine, ABS. Airbags or Electric Steering
everyting is OK.
When I try connect everyting else it not connect
AND I allways get ELM 327 CONNECTION FAILURE.
I have ELM 327 1.4 and VAG KKL and neither is working.
I have done both of the adapters A1 and A2 and try both.
I need to use Service interval reset.
Is it bug on FES 3.2 or do I something wrong?
Joolri
Posted: 07 Sep 2011, 02:45
by ARomeo
Doesn't work well with Delphi two zone climate control - Alfa 156 (sensors for sun radiation - 0%, temperature sensor right 1 is nothing, test - doesn't work,
Posted: 07 Sep 2011, 19:13
by Joolri
I found the solution to my problem.
ELM 327 1.4 dont work
I read this forum and I found Yani´s instructions and
I take R14 resistor away from my interface but i dont
sold any new capasitors or resistrors to ELM 327 interface.
Now everything works like a dream.
Thank you very much for your advice.
Joolri
