Multiecuscan 3.2 RELEASED!!!
Re: Multiecuscan 3.2 RELEASED!!!
Dear Yani,
I very much appreciate your software and I was happy to see that the latest version also supports the engine ECU for a Alfa 159 3.2.
However, after connecting to the ECU, I can only see the Info and Error screen, but the Paramaters and Actuator screen are not present. Is this part not yet fully functional ?
Regards
Regards
From the Supported Vehicles List:basjan wrote:Dear Yani,
Regards
Bosch Motronic MeD7.6.2 CF4/EOBD Injection (3.2) |INFO|DTC| KL ELM OBDKey
So only ECU information and fault codes available at present.
Thanks, a typical case of RTFMJuggers2k wrote:From the Supported Vehicles List:basjan wrote:Dear Yani,
Regards
The function Service Reset for Ducato 3,0 JTD is new in version 3.2 (I use ELM 327), but it will not work.
The problem is, that I got the failure notice “False ISO Code” when I use the function.
False ISO Code: 32 83 23 85 32
When I do the scan of the whole system, than it shows for Instrument Panel (Armaturen) :unknown/unsupported
Solution found!!! Search the theme: Problems with Ducato 3,0 DPF Service Reset
There is another bug in this version of FES software...
Again problem with Service Interval Reset!
I CAN DO the service coupon, BUT I CAN NOT do the:
- “Set the date until next service interval”
- “Set the km until next service interval”
I did not have any luck with this!
Tested on a Fiat Punto 2003 1,9JTD (new MY '03)!!!
Hello Yani,
Love the software really do! I started working with it this year en I helped me and the Dutch Fiat Bravo/a Marea club alot.
But theire is one engine that I cannot read atm and a lot of our forum users have this ECU. It's the bravo/a marea delta 1.6 16V (IAW 1AF).
Is theire a possibility that you can add this ECU so I can make a lot of people happy?
All the other engines don't give a problem but this is a very common engine here, hope you can help!
Thanks in advance, Best regards Ruud van der Horst The Netherlands
Hello Yani
Expected to be included in key (remote key) program function?
Krisztian
Krisztian
I have registered version FES 3.2
My car is Stilo 1.6. 2003
When I connect engine, ABS. Airbags or Electric Steering
everyting is OK.
When I try connect everyting else it not connect
AND I allways get ELM 327 CONNECTION FAILURE.
I have ELM 327 1.4 and VAG KKL and neither is working.
I have done both of the adapters A1 and A2 and try both.
I need to use Service interval reset.
Is it bug on FES 3.2 or do I something wrong?
Joolri
everyting is OK.
Joolri
Doesn't work well with Delphi two zone climate control - Alfa 156 (sensors for sun radiation - 0%, temperature sensor right 1 is nothing, test - doesn't work,
I found the solution to my problem.
ELM 327 1.4 dont work
I read this forum and I found Yani´s instructions and
I take R14 resistor away from my interface but i dont
sold any new capasitors or resistrors to ELM 327 interface.
Now everything works like a dream.
Thank you very much for your advice.
Joolri
Joolri
