Proxi in Panda
Re: Proxi in Panda
The mileage correction is already available in Multiecuscan 3.1.
Re: Proxi in Panda
yes, I noticed Yani and big big thanks to you for that. I also found option to turn temperature reading on, rewired the sensor directly to dash and it worked. It seems, that early Pandas had strange wiring unlike the newer ones (does not necessary have to be same as eLearn claims). I don't know what the wires I had it attached to, do in my gf Panda, but definitely they're different in color to the supposed cables in instrument cluster, so I run a stretch of wire from doors directly to IC and it worked
Once again Yani, you saved my day
Fiat Panda 1.1 2004 & Fiat Punto 1.2 60 1998
