Page 2 of 2
Re: Injector Coding NOT WORKING on 159 2.4JTDm
Posted: 30 Jul 2011, 07:26
by sarkan
The same problem, coding not workong on Alfa 156 2.4JTDm EDC16c8. Elm and KKL - both write, that it´s done, but codes are still the same.
Posted: 30 Mar 2012, 14:25
by alahou
Hello Yani,
I have bought Fiat ecu scan to change injectors code wiyh an ELM interface. Is there any chance that I can do with this interface or it is still not working?
alahou
Posted: 30 Mar 2012, 16:38
by alahou
I sent you a report Yani, my car is an Alfa GT 1,9jtd 16v
Posted: 30 Mar 2012, 16:58
by yani
Unfortunately, you have to try with a VAGCOM/KKL interface.
The command for injector coding is not supported by the ELM interfaces. It is some kind of bug in the interfaces. I have only one ELM which works fine with injector coding and many ELMs which do not work. All other interfaces (VAGCOM/KKL, OBDKey, OBDLink, CANtieCAR) do not have problems with the coding....
Posted: 30 Mar 2012, 17:03
by alahou
Ok thanks, then I will try with a KKL
Thanks for thequick answer
