Page 2 of 3
Re: Visteon Instrument panel does not show outside temperatu
Posted: 03 May 2011, 08:16
by yani
I'm still reading the documentation about this problem. I cannot find any difference in the CAN messages between the old and new instrument cluster.
Anyway, just to be sure that we tried the simple things... You can try the following.
1. Double-check that with multiecuscan you can read the correct temperature from the Driver Door module when the new Instrument Cluster is installed.
2. Do a PROXI Alignment with Multiecuscan after installing the new Instrument Cluster.
3. Try to change the degrees Units on the Instrument Panel (from the menu) and see if it makes any difference.
Posted: 04 May 2011, 10:18
by gioz
Hi Yani,
I did the test ....
1. With the old instrument panel, the outside temperature is displayed on the display.
With the new instrument panel, the temperature does not appear and is -40 ° C in diagnosis.
This occurred with Multiecuscan and Examiner.
Connected to the node Drivers-Door, the outside temperature is detected correctly with both the new and the old instrument panel installed.
The difference is that the new instrument panel is no longer displayed.
2. PROXI Alignment performed con Multiecuscan and Fiat Examiner serveral times, without positive results for the problem.
3. I changed the temperature from the menu of the instrument panel in "° F" but the result does not change the outside temperature is still not displayed.
In summary:
New cluster installed:
Drivers outside temperature detected by the node-Door: Right.
Outside temperature indicator on the display of the instrument panel: not shown. (-40 on diagnosis)
PROXI Alignment not solve the problem.
Old Cluster Installed:
Outside temperature detected by the node-door Drivers: correct.
Outside temperature indicator on the display of the instrument panel: correct.
PROXI Alignemt not necessary, all correct.
The part that runs/plays the outside temperature must be slightly different trail new and the old instrument panel. For this reason not be displayed.
Posted: 11 May 2011, 11:06
by gioz
news yani?
thanks
Posted: 16 May 2011, 09:27
by gioz
Hi Yani,
I replied via email,
I tested and sent you the report.
Let me know!
Posted: 16 May 2011, 16:15
by yani
Yes, I know... and it did not work.
I'm thinking of some other method to activate it.
Can we get a PROXI or CAN Info report from a newer Stilo which has an instrument cluster like your new cluster?
Posted: 16 May 2011, 18:04
by gioz
unfortunately no ... at least in this period: (
Posted: 23 May 2011, 18:42
by gioz
Hi Yani,
I found a friend with a Stilo MY2006 but can not send the report via the internet there is a way to have it in txt format?
Posted: 04 Jun 2011, 18:28
by gioz
Yani nothing to do, I'm still looking for a Stilo 2006 because my friend was pulled back...
Posted: 24 Jun 2011, 11:48
by gioz
nothing, I could not find anyone! : (: (: (
You can do anything you Yani?
Posted: 27 Jun 2011, 09:21
by yani
Yes, I have something for you... not sure if it will work but we'll test it.
I will send you an email in a few days.
