[FIAT BRAVO '07 1.9 MJET 16V] Torque sensors calibration
Gianremo
Re: "Torque calculation error"
Post by Gianremo »
EnIgMa wrote: ps.
i'm italian too xD
ciao ciao
[ot]
ciao ciao ;)
[/ot]
tomsa
Post by tomsa »
A. Mugnano wrote: i've changed turbo (garrett gt2256v), intercooler, exhaust manifold, air filter , downpipe , reinforced clutch,complete exhaust and a ECU remap.....anyway the gearbox it's stock and work fine :D
Hi, just one question: Do you know which gearbox you have, is it the same as in my Alfa 159, is it called M32?
If it is the same I would be interrested in your reinforced clutch. where do you buy it, how expensive, what type?
Thank you.
Tom
P.S. Do you have Galletto (EOBD) 1260 or similar to read out your ECU bin file? Would be helpfull to find limitations.
http://tomsa.bplaced.net
A. Mugnano
Post by A. Mugnano »
Thank you.
Tom
i've installed a kit like this ( http://lnx.protoxide.it/shop/product_in ... cts_id=833 )
Sorry but i don't know wich type of EOBD used to read the ECU .bin file becouse the hardware isn't mine.
Gianremo
Re: [FIAT BRAVO '07 1.9 MJET 16V] Torque sensors calibration
Post by Gianremo »
up :(
A. Mugnano
maded some short log session in FES.....hoping someone find fault or mistakes :(
FESLog_1104091854_FIAT BRAVO '07 1.9 MJET 16V.txt
(6.57 KiB) Downloaded 567 times
FESLog_1104091841_FIAT BRAVO '07 1.9 MJET 16V.txt
(15.65 KiB) Downloaded 542 times
FESExp_1104091850_FIAT BRAVO '07 1.9 MJET 16V_File1.csv
(7.04 KiB) Downloaded 561 times
tomsa
Post by tomsa »
hi,
had a look at your measurements and found no fault.
But I need a csv file with the following important parameters: engine speed, boost, intake air quantity, fuel pressure, pedal [%], Total Fuel Quantity[ mm³/i].
You must do that in minimum 3rd gear, because 1. and 2. gear are limited.
tomsa
A. Mugnano
tomsa wrote:hi,
tomsa
Ok, next time i will do the session with the parameters that you listed.
Only one thing....i have to to the test in minimum 3rd gear at full throttle?
Thank you
tomsa
Post by tomsa »
Yes, minimum 3rd gear better 4. or 5, gear and full throttle. Best from 1000 rpm to 4000 rpm.
As you can see in your csv-file the fuel is limited somewhere at 26,214 l/h
ciao
tom
JOSEPH1975
Post by JOSEPH1975 »
Hello to everyone.
after a remap i have DTCs P091B/P061B errors.
Have you tried a solutions?
Sincerely.
EnIgMa
Post by EnIgMa »
what are those dtc?
