Page 2 of 2
Re: HITACHI MFi-018 support?
Posted: 09 Mar 2011, 21:03
by molej
In my car, Marea 1.8, '99, is 2nd version of ECU. It's supported in latest version FES. But...
When I trying to connect with ECU, there is a problem... FES can't connect (airbag and ABS works fine)
When I scanning, I have that message:
VAG-KKL interface + 3 pin adapter, Windows XP SP3.
GND on 3-pin interface (in car) is ok, also K-line...
I was trying with many difrent drivers and configurations....
What's wrong? My car is not supported in FES?
Best regards
Math
Posted: 12 Aug 2012, 16:59
by hitman142006
Hello everyone.
I kept trying to connect to my ecu but no luck. I can communicate with the ABS an airbag so the cable is ok.
Now I have a imobiliser problem and want to get the full version to try and fix it but I can't communicate with ecu.
Do you happen to know if the pinout for the Hitachi MFI is the same as the MPI one?
All the best, Cristi
Posted: 17 Aug 2012, 17:42
by hitman142006
Anyone around here???
Posted: 21 Aug 2012, 11:38
by mattydr67
In which car mate?
Posted: 22 Aug 2012, 18:17
by hitman142006
It's a 1996 1800cc 16V Fiat Coupe.
I've tried all the list of ECUs in fiat ecu scan and not connecting.
The cable is ok I think as I can communicate with abs.
Still no luck with the airbag and the ECU!
Posted: 08 Nov 2012, 16:31
by hitman142006
Any support yet?
Posted: 10 Nov 2012, 08:31
by yani
Please do the following:
1. Connect the cables to the 3-pin connector of the engine ECU
2. Execute the SCAN function
3. Try to connect by selecting "Hitachi MPI injection" from Coupe'96 1.8 16V
4. Click the red Send Report button to send me a report about the connection
5. Give me the date/time when you sent the report
I will check the report to see if there is any response from the control module.
Posted: 26 Nov 2012, 19:26
by hitman142006
yani wrote:Please do the following:
OK. Will try tomorrow and send the report.
Many thanks in advance.
All the best,
Cristi
