I have one question for both of you:
-do you know where I can find the AIRBAG connector for Lancia Kappa 2.0 from 2000?
Since you both have a Lancia Kappa I was wondering where did you find this connector?!?
I know that connector for ABS ECU is close to battery. And connector for engine ECU is under steering wheel.
But have no idea where is this AIRBAG connector...
Many thanks
The airbag diagnose connector for Lancia Kappa is located under the console and can be reached via a small removable plate (10x15cm) located at the passenger site. (if you sit on the passenger site and you move your (stretched) left feet to the left you will hit that plate).
esmill wrote:The airbag diagnose connector for Lancia Kappa is located under the console and can be reached via a small removable plate (10x15cm) located at the passenger site. (if you sit on the passenger site and you move your (stretched) left feet to the left you will hit that plate).
esmill
Thank you very much!
