Re: Odometer doesn't show correct value
Posted: 10 Feb 2011, 18:58
Dont know why though. But at least I have the full service history of my car so at least I know the KM reading is true.
Support message board
https://multiecuscan.net/forum/
I would always advise you to drive a car for a few kilometres and than you will see is the right value or not.Boris wrote:Are you sure that it is a ECU problem? and not a indication that somebody changed odometer value?
I have seen few 147 with correct odometer values, and few with values like that (600-700 000 km).
All cars with correct values had only one owner, and cars with big odometer values were from 3-4-5-th owner, and looked like some previous owner was cheating with km on odometer.
I agree with you! There is a problem in ECU! But on later models Alfa Romeo fixed that problem. I tested a lot of Alfas, especially models 147 and 156 and I got this conclusion:Boris wrote:Yesterday connected on 147 1.9 JTD 8V, and there was a big difference in km value - approx 1:3. (for 1 km in dashboard, ecu/odometer shows approx 3 km when cars is driving).
Not only FES shows a difference in value but also a Fiat examiner (both km values are the same in FES and Examiner), so this error is not an error in FES, but probably in ECU?
My experience is not the same:alfa156sarajevo wrote:I agree with you! There is a problem in ECU! But on later models Alfa Romeo fixed that problem. I tested a lot of Alfas, especially models 147 and 156 and I got this conclusion:Boris wrote:Yesterday connected on 147 1.9 JTD 8V, and there was a big difference in km value - approx 1:3. (for 1 km in dashboard, ecu/odometer shows approx 3 km when cars is driving).
- all AR 147 models (face lifting) from 2005 and AR models 156 from 2001 are showing the right value in the odometer (dashboard and FES). Maybe it can lie up to 3% and that is it!
- all AR 145, 146, 147 models (until 12/2004) and AR 156 models (until 12/2000) are showing wrong value in the odometer. Dashboard odometer is showing one value and FES is showing the different value. You need to drive car for a few kilometers and with some math you can calculate the approximately odometer value.
Kao što sam ja napisao, ove dvije 147 2.0 2003 i Alfa 147 jtd 8v 2002, imaju obje kilometraže slične tj. kilometraža na kontrolnoj ploči je jednaka kilometraži kad se sa FES-om priključiš na Servisni interval, i ta je kilometarža slična kilometraži u Engine ECU tj motoru. Obadve te Alfe su normalne prije facelifta.alfa156sarajevo wrote:Da... Mislim da kilometraža koja je "trenutno" na instrument ploči ne odgovara onoj kilometraži koja je zabilježena u "Engine ECU", odnosno u motoru.![]()
Eto vidiš, ja sam testirao par modela Alfe 147 JTD iz 2002. godine i kilometraža bila oko 1 milion, odnosno oko 200 000km nakon malo vožnje i malo matematike...
Vjerovatno su te alfe koje sam ja "testirao" bile modeli iz kraja 2001. godine, a u papire upisane kao 2002. godina proizvodnje... Odnosno "ubačen" im stariji ECU sistem...
