add ecu iaw 6/8/16/18 F
Re: add ecu iaw 6/8/16/18 F
I would like to know how is it possible that the new FES doesn't have engine support for Bravo 1.6 model year 1996 but has engines for all other Bravo models?
and I also have Fiat Coupe 16v turbo, for that car there is only option Airbag diagnostic, can you tell me will the engine and abs also be suported in the future for this car? I ask this because I cant do diagnostic on my own car
crazydrake
Yani please help us to connect to our old ECU's. (sorry for my english)
See attachments for communication protocol specifications of old FIAT ECUs. They are mostly in Italian, but I think, that is not a problem.
- OLD_IAW_SPEC.zip
- Diagnostic protocol specs for:
IAW-1AF, IAW-16F, IAW-18F, IAW-P8 - (1.68 MiB) Downloaded 770 times
Hí Yani , please , add the old ECUs in the multiecuscan .
My car is old .
Thank you.
My car is old .
Thank you.
There are lots of ECUs that are still not supported in multiecuscan.
Please be patient!
Please be patient!
We, or at least I, are patient and just would like to know if you have plans to introduce a support for those ECUs at all. Their implementation is relatively easy in comparison with the newer ECUs like IAW-49F, not talking about CAN based ones.
Hí Yani , thanks for replying , we`ll be waiting , oldies ECUs in the multiecuscan.
Thanks.
Thanks.
the_old_lover
Hi,Yani i know that you have a lot of work with all new models,but when you will do something for us with the old cars?I hope you are thinking to ad some of the older ECU in the program.Thanks
I belive you have a template (a class with an interface to implement) for adding new ECUs, so maybe you could let the volunteers to add support for some ECUs?
I have a Fiat Siena Year 2002
IAW 18F.B4/070U-1A
1781242 MPI TURCHIA 1781242
46791210.61600.568.002 12V
motor 178B5000
Vin NM4178000A06276844
The still has the 3 pin plug.
The list does not exist.
Is this ECU available in FES?
greeting
wombi
IAW 18F.B4/070U-1A
motor 178B5000
greeting
wombi
