Page 2 of 3
Re: GENDAN creates FIAT ECUSCAN Hardware/Cable Set
Posted: 02 Feb 2011, 13:55
by yani
This error means that there is a problem with the signals on CAN network.
Check if your battery is ok. The ELM interfaces are unstable when the power supply is low.
Check if the OBD connector is plugged in well.
Send a report using the red "Send Report" button after unsuccessfull connection so that I can check the problem.
Posted: 02 Feb 2011, 19:09
by dave fiatforum.com
ok will do, i'll have to try and get hub nearer to the car so my wi-fi will connect
thanks
Posted: 03 Feb 2011, 00:05
by EnIgMa
WOW, thanks for sharing this info!
Sometimes I'm very lazy, and seriously I wasn't that happy to modify my cable...again! :D
I'm really thinking to buy those 3 adapters ;)
Posted: 03 Feb 2011, 17:28
error report sent, i left battery charging by engine running for half hour whilst i looked for new cable so i could get wi-fi out side, didn't have time to check it with a meter as bonnet cable is snapped so i have to get that open first :(
Posted: 04 Feb 2011, 11:45
did you get the error report?
Posted: 04 Feb 2011, 19:00
by yani
Yes, I got the report...
Unfortunately, I cannot say anything more about your problem. The ELM interface simply fails to connect or disconnects from the body computer. It could be low power as I already mentioned, or bad cable connections, bad earths. I don't think that it is a problem in the driver or settings.
You can try to connect to another car and see if everything will work fine there or not.
Posted: 04 Feb 2011, 19:17
i managed to get bonnet open, battery is at 12.20 volts on the meter. i'll try it on my own car then
Posted: 04 Feb 2011, 20:31
it conected fine on my car 2001 punto 16v
so ive put battery from problem car on charge hopefully its just that.
thanks for the help
Posted: 06 Feb 2011, 17:52
I charged battery for problem car it read 13.9 volts after i let it settle after charging, put it back in the car and dash display stopped flashing so i didn't need proxi alignment after all :oops:
how ever since i tested it on my own car i have throttle learn problem have i messed some thing up? i connected it again to my car to try and run proxi alignment but it failed, i sent new error report
Posted: 08 Feb 2011, 16:15
BTW even though charging up the battery stopped the dash from flashing I an still unable to connect to do the proxi alignment on the 2005 1.2 8v punto.
sent new error report aprox 16.14 gmt. is it reporting same thing as before?
