Fiat Bravo won't start after self learning reset
abarthmultijet
Re: Fiat Bravo won't start after self learning reset
Post by abarthmultijet »
Seistar wrote: 18 Apr 2025, 05:46 Great 👍
It feels like the beginning of a solution, let's check this.
Did you find the solution?
Seistar
Post by Seistar »
Hi.
After some more tries, the no start issue has been solved, thanks again for you help.
First the MAF sensor disconnected didn't make no change. I decided to install the new EGR i received.
When I unscrewed the old one, it kind of pop out itself, with a spring sound. The problem was the round metal joint in the EGR location. When I put the EGR back after cleaning, I didn't realise the joint was misplaced inside, and bent when I screwed the EGR in place. Thus it blocked the EGR open at the first move.
So definitely a blocked EGR can cause a crank no start.
After that, the car started normally. I decided to install my new EGR anyway, and it doesn't work (no signal received)....
The car runs fine with the old clean one, so it will stay like this!
Thanks again, hope it could help others.
