FESmobile 2.0 Released!!!
FESmobile - Windows Mobile version of Multiecuscan
eric
Re: FESmobile 2.0 Released!!!
Post by eric »
You will release a update for the Valeo Parking Control issue.
Must i uninstall the old version or is it the same procedure like the normal FES?
petania
Post by petania »
I try to instal Multiecuscan Mobile on DELL AXIM with Windows CE 4.2 on it. After update with .NET Framework 3.5 I finaly succeed with the instalation. However, after I select the type of ECU and proceed by pressing Simulate or Connect, error mesage appear:
An unnexpected error has ocoured in FESmobile.exe.
Select Quit and then restart this program, or select Details for more information.
Can't find Entry Point 'Alpha blend' in a PInvoke DLL 'coredll.dll'
As much I understand FESmobile need to start alphablend function in order to show some semi-transparent components and did't succeed.
Is there way to get round this issue?
I'm ready to send Detail information about this error and any needed data.
http://snimki.be//store/1/501333389454.JPG
Best regards
Petania
