Thanks !!!
Noticed that Lancia Thesis 2,4 Mjet Aisin Autom gearbox was added.
Missed this before. Will test later. Many owners complain about late up-shifting.
Try to adjust.
Did reinitialisation of tranny, and shifting is now much better(sooner).
I know this can be done manually (see E-Learn Thesis) and that coolingfluid temp. as well as
tranny atf temp should be within certain limits. Now we can check both thru FES!!
So i did the reset when both temps were within range, just to be safe!!
I own an Y10 with the references below, will this new version support Bosch MA1.7 (using ELM327 V1.4a)
I've read that it supports MA1.7.3, but what about MA1.7? is it the same?
Connecting My interface using a 3pin adapter to my Y10 seems Ok as the TX and RX leds are blinking on both sides, (while they stay steady on my Xsara VTS HDi 110 with VAN protocol). I've tested V 3.2 and my Y10 is not recognized. will this 3.3 recognize it?
Y10 references:
Mode l: Y10 LXie 1.1 litre
Year: 91-95
System: Bosch MA1.7
OE Ref. No.: 0 261 200 716
VM Ref. No.: 7778785
ATP Pt. No.: XEBS0716
beowolf wrote:still no support for ECU Marelli IAW 1AF for fiat brava 1.6 16V ??????? Why???? I'm ready to buy FES if u add this car. Lots of ppl will buy it I think...
I completely agree. Support Fiat Brava 1.6 16V is necessary.
Y10 references:
Year: 91-95
System: Bosch MA1.7
Many thanks for your help.
Best regards,
Olivier.
MA1.7.3 works only with KKL/VagCom and OBDKey 1.40.
