ruda30
Post by ruda30 »
Zwierzak wrote:You have to remove R14 / Musisz usunąć R14
Ahoj a mužeš mi poslat nějake schema zapojeni prosimtě nechci zapojovat a odpojovat na slepo dik
BestiaRO
Post by BestiaRO »
i have an ELM 327 1.5a and i can't connect to body,service etc
on engine is working perfect
if i will remove R04 everything will work ?
Zwierzak
Post by Zwierzak »
R14 or R04 ???
As I can see there R14 must be removed
khropek
Post by khropek »
I have ELM327-USB V3.0 interface like picture in this post viewtopic.php?f=5&t=1493&start=120
I have Alfa Romeo 147 1.9JTD 115KM 2001 and I can connect with ECU but I can`t change injector code.
ECU ISO Code: FD 86 13 80 6B
2011-10-22 12:05:40
CONNECTED TO:
ALFA 147 1.9 JTD
Bosch EDC15C7 CF3/EOBD Diesel Injection (1.9, 2.4)
ECU ISO code: FD 86 13 80 6B
FIAT drawing number: 46784814
Hardware number: 0281010332
Hardware version: 00
Software number: 1037354624
Software version: 7400
Homologation number: 937A4A
ECU programming date: 02/19/2001
EXECUTING ADJUSTMENT...
Injector class (All)
Old value:
New value: Class 2
FAILED TO EXECUTE
BestiaRO
Post by BestiaRO »
nobody?
amiko
Post by amiko »
BestiaRO wrote:nobody?
Not sure.
You have different board.
ruda30
Post by ruda30 »
Zwierzak wrote:
R14 or R04 ???
Ahoj odstranim R14 a co dal musim tam něco přidělat nebo ne
ruda30
Post by ruda30 »
yincar wrote:Hi Yani and all,
My bad interface looks like this. Not sure which version it is. So, do i need to remove R14 and solder 100 ohm resistor and 560pf capacitor like what 1st post did to cure CAN issue?
yincar
Ahoj prosimtě mužeš mi poslat detalnějši připojeni capacitoru a resistoru Děkuji
Darren_W
Post by Darren_W »
Hello Friends.
Lots of very interesting posts about interfaces which are not working correctly.
Can some one give us a link for a known good tested interface / supplier ?
Many Thanks
Darren
pls
Post by pls »
sprint750 wrote:Hello,
It was sold as ELM 327 1.4 'with a genuine ELM chip'. :?
Best regards
Sébastien
it seems I do have this one interface. I did soldered additional pins. So, at this time I'm able to connect to engine ECU and ABS in my Alfa 147. Unfortunately I cannot connect to anything else.
This is result of Interface scan
Scanning ...
ELM 327 interface found at port COM2, speed 38400bps
This interface is compatible with ELM 327 1.3! Should connect properly with all CAN modules.
Latency Too High!!!
This is results of interface test
RESPONSE: ATZ ELM327 v1.4a >
RESPONSE: ATI ELM327 v1.4a >
RESPONSE: ATE0 OK >
RESPONSE: OK >
RESPONSE: OK >
RESPONSE: OK >
RESPONSE: OK >
RESPONSE: OK >
RESPONSE: OK >
RESPONSE: OK >
RESPONSE: OK >
RESPONSE: OK >
RESPONSE: OK >
RESPONSE: ERR94 >
Can anyone help?
