Odometer write
taki--jeden
Odometer write
Post by taki--jeden »
Hi, I have orginal odometer 75000.
Now i have changed dashbord because I activated cruise control and want light control for it.
Now new odometer value is 28986 and when I checked ABS, Airbag, etc everywhere is 28986 (even after proxi alignment).
Should I use odometer write function to make it like before change? Will it affect on rest of modules?
kris
Re: Odometer write
Post by kris »
Do you have a blinking mileage? You can only use the write function once. After you changed the dashboard, did the speedo meter work ? And after you did a proxi alignment, did it then work ?
taki--jeden
Re: Odometer write
No, My milage wasn't blinking. Spedometer works fine. When I made proxi alignment works too.
