software update for fiat,alfa
hello yani, it is possible to make an software update for ecus , with fes? best regards
Re: software update for fiat,alfa
No, FES is not working in this mode.
- try use Galletto or KWP2000.
hello thank you for your help. when i buy the galletto interface, what for a software i need ? regards
you have to read out your ECU with the galletto tool (you can buy at ebay from hongkong, software is included), remapp the software and flash back to the ECU. Have a look on my facebook site for more details. For a littel donation I can do remapping for you if you have a car with BOSCH EDC16C39 ECU.
tomsa.
tomsa.
Alfa 159 JTDm +360Nm@2000rpm+EGR shutt-off+Regeneration off
http://tomsa.bplaced.net
http://www.facebook.com/pages/My159/176949985681507
Hello tomsa
I have read with interest your report.It concerns the Galletto 1260.
Have sent a mail also.
I have an Albea Multijet 1.3 can you raise as the force in the lower speeds something with the Galletto?
Greeting
wombi
Greeting
wombi
Ciao Wombi vedi che non è il Galetto che gestische il cambiamento del sw-della centralina ma fa solo lettura è scrittura,dopo aver letto la centralina ci sono diversi programmi che modificano i parametri,poi riscrivi la centralina,ma in merito alla tua versione di centralina anche modif. i parametri non avrai risultati eccessivi a bassi regimi-solo dopo i 2000giri-provato su propia vettura,perchè se dai troppo gasolio ai bassi-dopo accellerazione si vede troppo fumo nero fastidioso per chi è dietro la tua vetturawombi wrote:Hello tomsa![]()
I have an Albea Multijet 1.3 can you raise as the force in the lower speeds something with the Galletto?![]()
Greeting
wombi
saluti
Sorry I translated with google Hello What you see And the Womb Galetto What gestische the changeover of the unit but it sw solo reading and writing, after reading the ECU we are diversifying programs that modify the parameters, then rewrite the unit, but regarding your version of Also change control. the parameter will not take an excessive low speeds results-only AFTER the 2000giri propia-tested on the car, because if the low-Diesel From Too acceleration instead AFTER YOU Too annoying for who and black smoke behind your car
salutiAron96
salutiAron96
Hello aron96
first thanks for the reply.
I'm new with the Galletto.Habe not ordered.
I have me times the software downloaded and tried there already exists a log to edit files.
Failed but me.
What an editor is it operated?
many greetings
wombi
Failed but me.
many greetings
wombi
For Tomsa
Can you also shut down the RGR valve with the galletto 1260 , because I tried it manually than you get the problem of running in problem mode because of less nox value.
EGR valve off and DPF regneration off no problem for me whenn you send me your ECU file.
Tomsa
Tomsa
