grande punto 1.9 mjet engine ecu
Why the engine ecu of Grande Punto 1.9 multijet is not supported yet? It's possible made a diagnosis using the scanner for edc16c39 on fiat bravo or croma 120hp? Also the Idea and Musa 1.9 multijet engine ecu aren't supported, whilst the same engine is supported on Punto 03 (edc16).
Re: grande punto 1.9 mjet engine ecu
Unfortunately it is not possible to use the ECU from Bravo or Croma for Grande Punto. It is completely different.
However, you can try the EDC16C39 ECU from Alfa Mito 1.6MJET. It is much more similar to the one in GP.
Thank you!
