Grande Punto Cruise control aftermarket
Re: Grande Punto Cruise control aftermarket
Where did you manage to get the Cruise control unit from?
I got it from my local FIAT dealer at the second attempt. First he ordered the one i already had......
Do you by any chance have the part number? and how much did it cost if you don't mind me askingholbli wrote:I got it from my local FIAT dealer at the second attempt. First he ordered the one i already had......
Part number is 735521318 and it cost around 185€. Not cheap, but i drive 150km per day mainly on a highway and it was worth it.
I must add, that there isnt a LED in the dash. That is why it wont light up.
It is pretty easy to add it. You need one green 3528 plcc2 smd led and solder it on the board.
I'm going to get CC soon on my 2008 tjet.
I'll let you know
ps.
did you know that the activation procedure can terminate correctly but CC won't work (only for the for the first time) if you don't try it above 40Km/h?
I'll let you know
ps.
is there anything new or some progress with MES(FES) to add activation for Grande punto from y. 10/2008 --> ?
Before that date it works fine.
I've got GP y. 10/2008, I put an aditional cabel for CC and I activated it with FES and the activation was succesful, but it doesn't work because it was made y. 10/2008. The LED light is also alredy in and it works in FES, but not with CC when is turned ON.
Does anyone know what should be the intensity of this led?maliomladinac wrote:I must add, that there isnt a LED in the dash. That is why it wont light up.
No success at all with Grande Punto 3/2008. I added aditional wire to the body and made successfull PROXY Alignment but the CC is not working. The strange is that the cable colors on connector D on the BODY Ecu are different. I compare with the pictures taken by Thibag64. Here are the logs:
ECU ISO Code: 40 83 23 04 BF
02.12.2012 10:53:39
CONNECTED TO:
FIAT GRANDE PUNTO 1.3 MJET 16V
Delphi Body Computer
ECU ISO code: 40 83 23 04 BF
FIAT drawing number: 51798615
Hardware number: 28122166
Hardware version: 04
Software number: 28117218
Software version: 0029
Homologation number: 000639
Functioning time (EEPROM): 160183
Operating time: 161073
CAN CONFIGURATION DATA:
6F 00 00 04 00 00 00 00 6F 00 00 04 00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00
6F 00 00 04 00 00 00 00 09 00 00 04 00 00 00 00 6F 00 00 04 00 00 00 00 09 00 00 04 00 00 00 00 09 00 00 04 00 00 00 00
30 31 31 39 39 30 30 30 30 32 31 4F 55 54 50 55 54 2D 4A 49 54 20 06 06 15 6F 00 00 04 00 00 00 00 09 00 00 04 00 00 00 00 C1 00 03 07 3F 00 2A 10 83 80 00 06 00 00 00 14 06 01 02 00 00 00 00 00 0A 10 05 0C 0D 00 00 00 00 00 00 00 00 11 0D 50
CURRENTLY CONFIGURED CAN MODULES:
Body Computer Node (NBC)
Engine Control Node (NCM)
Electric Steering Node (NGE)
Dashboard Node (NQS)
Receiver Radio (NRR)
Brake System Node (NFR)
Airbag Node (NAB)
CURRENTLY AVAILABLE CAN MODULES:
Airbag Node (NAB)
CAN MODULES THAT REQUIRE EOL PROGRAMMING:
Airbag Node (NAB)
02.12.2012 13:51:28
CONNECTED TO:
CURRENTLY CONFIGURED CAN MODULES::
Body Computer Node (NBC):
Engine Control Node (NCM):
Electric Steering Node (NGE):
Dashboard Node (NQS):
Receiver Radio (NRR):
Brake System Node (NFR):
Airbag Node (NAB):
CURRENTLY AVAILABLE CAN MODULES::
Airbag Node (NAB):
CAN MODULES THAT REQUIRE EOL PROGRAMMING::
Airbag Node (NAB):
EXECUTING ADJUSTMENT...
Cruise control
Old value: Enabled
New value: Enabled
COMPLETED
PROXI ALIGNMENT PROCEDURE
Writing to module: Dashboard Node (NQS) FAILED! - Request out of range error
Writing to module: Airbag Node (NAB) SUCCESS!
FAILED TO EXECUTE
02.12.2012 10:53:39
CONNECTED TO:
Airbag Node (NAB)
Airbag Node (NAB)
Airbag Node (NAB)
02.12.2012 13:51:28
CONNECTED TO:
Airbag Node (NAB):
Airbag Node (NAB):
Airbag Node (NAB):
Cruise control
Old value: Enabled
New value: Enabled
COMPLETED
FAILED TO EXECUTE
Yani, do you thing that CAN Info from GP 5/2008 would be usefull for impementing CC functionality for year 2008+. The CC on this car is activated with Leonardo and I asked the owner for FES logs.
