Multiecuscan 3.2 RELEASED!!!
I released Multiecuscan 3.2 today with the following changes:
- Added Bulgarian data language - actually ~60% of the data is translated in BG, the rest will be available in next release
- Improved Russian data translation
- Improved Polish translation (thanks to @tzok)
- Improved German translation (thanks to @belli29)
- Added support for ALFA GIULIETTA
- Fixed a bug in error reading code for some old ECUs which caused the program to hang
- Added possibility to record non-numeric data in the CSV export files
- Fixed 'simulation' mode not activating with CRTL+mouse click on CONNECT button
- Added more PROXI configuration options and improved PROXI procedure
- Support for Bosch MSA 11 Diesel Injection (2.4) (Marea 2.4TD/K 2.4TD) (Full support) (Fixed the problem with connection to this module) - There was a bug in previous versions and connection to this ECU was actually not possible
- Support for Fiat Ducato Service Interval Reset
- Support for Delphi climate control/Single zone (147/GT) (Full support)
- Support for Delphi climate control/Dual zone (147/GT) (Full support)
- Support for Delphi climate control (156) (Full support)
- Support for Marelli Connect (All models) (Info and DTC only)
- Support for Marelli/Microsoft Convergence (All models) (Info and DTC only)
- Support for Lauberhorn Convergence (500, Punto Evo, Doblo) (Info and DTC only)
- Support for Valeo parking control (Grande Punto, Punto Evo, 500, Mito, Giulietta)
- Support for Valeo parking control 2 (Delta)
- Support for Bosch parking control (Bravo, Linea, Ducato)
- Support for Selespeed CFC328 Automatic Gearbox (Grande Punto, Punto Evo, 500)
- Support for Marelli 8DF CF5/EOBD Diesel Injection (1.3) (Grande Punto, Punto Evo, 500, Doblo, Mito)
- Support for Marelli Instrument Panel Base/Comfort (Punto, Panda, Idea, Doblo, Musa)
- Support for Bosch Motronic MeD7.6.1 CF4/EOBD Injection (159/Brera 1.9JTS/2.2JTS) (Full support)
- Support for Siemens navigator/ICS instrument (Alfa 166) (Info and DTC only)
- Support for ZF 4HP20 Automatic Gearbox (Alfa 166/Lancia K)
nielsek
Re: Multiecuscan 3.2 RELEASED!!!
Post by nielsek »
Great, that now ZF 4HP20 is supported! I can't understand, if an adapter cable is needed for gearbox?
Under Supported Vehicles it states: KL ELM OBDKey A1
So is ELM/KL OK? Or we really need KL1 ELM1 (with A1 cable)
Thanks in advance!
nielsek wrote:Great, that now ZF 4HP20 is supported! I can't understand, if an adapter cable is needed for gearbox?
Thanks in advance!
Yes, I'm adding these 166 modules by a request from the Bulgarian alfa club...
It actually depends on what model/year is your car...
According to the info that I have:
- on ALFA 166 '03 the gearbox is on pin 9 (which means that you need A1)
- on the older ALFA 166 it is on pin 7 and you don't need an adapter
- on LANCIA K it is with a 3-pin conector (so you need a 3-pin adapter)
So, there is an error on the supported vehicle list (for older 166s) but it is not very significant as adapter 1 has pins 7<->7 wired as well...
Alecto28
Post by Alecto28 »
Hello Yani,
just tried the Delphi climate control support for the 156, all works but not the actuator tests.
All say Failed to execute.
Cheers!
snuff
Post by snuff »
I downloaded FES 3.2 , free version. If i try to connect to my ecu (marelli 8DF), connection starts but a message says that only registered version could connect. Is it correct? I can't see any parameter without register? I'd like to test some functions before buying. I'm doing something wrong?
thanks.
snuff wrote:I downloaded FES 3.2 , free version. If i try to connect to my ecu (marelli 8DF), connection starts but a message says that only registered version could connect. Is it correct? I can't see any parameter without register? I'd like to test some functions before buying. I'm doing something wrong?
thanks.
Go to this link. http://www.multiecuscan.net/SupportedVehiclesList.aspx
There you can find your car and model and there you can see what kind of modules you can access with FREE and REGOSTERED version... ;)
There is a bug in this version of FES software...
Each time when I connect to a "Service" > "Service Interval Reset" I got this message:
"INVALID ISO CODE"
In earlier versions I never had this problem! :roll: The car is Alfa Roemo 147 FL 2005 1,9JTD! :roll:
alfa156sarajevo wrote:There is a bug in this version of FES software...
"INVALID ISO CODE"
Ok, I will fix it. Thanks for reporting.
TribesMan
Post by TribesMan »
Yani what about support for Aisin automatic gearbox in 166 2.4 20V? Is it possible to add that?
TribesMan wrote:Yani what about support for Aisin automatic gearbox in 166 2.4 20V? Is it possible to add that?
Yes, it will be supported soon.
Croma 2.2 is using this gearbox as well.
