not connect to engine ECU
pinout
Post by pinout »
Today I tried multiecuscan on my alfa 147 jtd 115cv but does not connect to engine ECU, which is the problem? but works well with ABS and airbags :|
TribesMan
Re: not connect to engine ECU
Post by TribesMan »
Do you have all pins connected in the cable? I think you need pin 7 for ECU...
And did you select the right ECU model?
laurentk
Post by laurentk »
hi,
can u tell me what do u mean whan you say " u need pin 7 for ECU"??
because i've a problem to connect on my alfa, u can see here :
viewtopic.php?f=5&t=350
regards
LK
xpmods
Post by xpmods »
update the drivers for your lead and reduce the buffer latency that worked for me.
laus
Post by laus »
haló,900mhz cpu,and xp ok?
