Hi, first of all my warmest congratulations for this excellent piece of work! But i´ve got probs... i get connected to the ecu but the programm prompts, that the iso number is not correct and it is not possible to mark any parameter for realtime scan. fault codes are displayed and can be erased. In unidiag the identification says, that i´ve got an edc 16c9 (not 16c8!). It´s an 156 SW 2.4 jtd 20v from Juni 2004 with 175 bhp.
thx a lot and a happy new year
Max
Alfa 156 2.4 jtd 20v MY04 probs
Re: Alfa 156 2.4 jtd 20v MY04 probs
What type of cable are you using to get the software to work with the ecu? I'm trying with a vag com kkl usb cable, but cannot connect to the ecu... and I have the same car as you.
Rgds,
Cris
Rgds,
Cris
EDC16/CF4 will be supported in the next release.
Hi, i´m using a vag kkl usb cable too. Thanks yani for your quick reply!!
max
max
Hi, now with version 1.6 the iso-code-error no longer appears but i´m still not able to select any of the parameters. When i click the checkbox - nothing happens!
Please help me!
Markus
Please help me!
Markus
Does anybody have the same probs or am I the only one, who cannot click the checkboxes to select parameters.
greetings from Austria
Markus
Markus
Hi,csac8600 wrote:Hi, now with version 1.6 the iso-code-error no longer appears but i´m still not able to select any of the parameters. When i click the checkbox - nothing happens!![]()
Please help me!
Markus
What do you mean by nothing happens? Does the checkbox change its state checked/unchecked? Does the colour of text turn to red?
Does the program show "serial port latency" message on bottom?
Does the program show correct ECU identification data?
You can post some screenshots.
somebody didn't read the "How TO"csac8600 wrote:Does anybody have the same probs or am I the only one, who cannot click the checkboxes to select parameters.![]()
Markus
you should press SPACE where you want to select the parameter - use arrow keys to slelect between the parameters
Shame on me, shame on me!!!
I was so curious about your programm, that i didn´t read the "how to" properly
Again I want to thank you for your effort! Great piece of work!!
greetings
Markus
greetings
Markus
