Outside temperature Panda
p.a.
Post by p.a. »
I saw there was an option of enabling outside temperature on Panda. I tried that, because my Panda does not tell me the outside temperature, however it didn't work (I did the proxi allaignment as FES tells you after changing this). Is it simply not possible because of the type of instrument cluster I have or is it somehing else?
It is a Panda Editzione Cool from 2008 with a/c, RPM meter and and with computer witch tells me the fuelconsumption and other different thinks. I have the basetypeservice interval (in my opinion no service interval).
Thank you in advance for your help.
Zwierzak
Re: Outside temperature Panda
Post by Zwierzak »
This option works only for emotion instrument cluster like this :
EnIgMa
Post by EnIgMa »
AND of course the sensor has to be installed properly..
kpematop
Post by kpematop »
do you have schema for Panda MY2012/Ypsilon MY2012 how to connect the external temperature sender?
waggos
Post by waggos »
i think the sensor would be in the side mirror and hard to add if you want to search for it you can try here http://4cardata.info/elearn/169/2
