Problem Connecting Hitachi MPI injection (pre98)
Re: Problem Connecting Hitachi MPI injection (pre98)
I will release version 2.8.2 tonight with fixed support for this Hitachi ECU..
yani - Thank you!
Last version works properly witch engine ECU:)
Best regards!
Peter
Best regards!
Peter
With 2.8.2 it is connecting with my '96 Fiat 1.8 Coupe.
Many thanks.
Ralf
Many thanks.
Ralf
Good Morning,
unfortunatly it still does not work on my barchetta '96.
Scan works, but connecting tells me check cable/interface.
I think, if the scan works, the connection cable->interface is correct, isn't it ?
What can I do ? System is VISTA SP2 and USB-KKl interface
Good day,
Which computer do you use? laptop or netbook?
Greetings
wombi
Greetings
wombi
2.8.2 works with a Lancia Delta Hitachi ECU '97. Great work
Did you check the common problems like interface driver and driver lattency settings?ubohli wrote:Good Morning,
Marea 1.8 -00. KKL-cable (Lenovo T61, Win7 pro) & multiecuscan 2.8.2
Connect ok, but jums everytime when i open "error sceen" and multiecuscan need close with "taskmanager". I cannot clear error and see what is the new error code.
http://aijaa.com/v.php?i=005798110069.jpg (first and second erros is okay, but i need to see description "error 87")
Version 2.8.2 works perfekt with my 96 Barchetta.
Now I just wait for Airbag support.
Thank you
good job
Thank you
good job
Espi wrote:Marea 1.8 -00. KKL-cable (Lenovo T61, Win7 pro) & multiecuscan 2.8.2
Change KWP2000 timing to "Optimal" works and errors reseted.
