I was trying to connect ECU with FES 2.7.2. I couldn't connect with KKL USB and 3pin adapter.
My car - Marea 1.8 - 1999/2000.
When I scannig it was that ISO code:
"ISO Code: 45 85 83 94 B6"
I was trying in FES with few cars in that same ECU -Bravo/Brava/Barchetta with the same results - no connection (I send reports)
With airbag and ABS FES connect very well.
Where is a problem?
Thanks for any tips
Peter
Hitachi MPI
Re: Hitachi MPI
I have the same problem. I found that same problem in different forums. I suppose that Multiecuscan don't work with Hitachi even if it said that he is...
Re: Hitachi MPI
Hello. I also can't connect to "Hitachi MPI injection ISO Code: 45 85 83 94 B6" (Fiat Marea 1.8 1997).
When i scanning with multiecuscan 2.7.2 with KKL and USB and 3pin adapter found Hitachi MPI injection ISO Code: 45 85 83 94 B6? but when i want to connect - I have a problem "Error. No ECU response. Сheck the cable and settings COM-port". The OS is WinXP SP3.
Thanks.
Thanks.
Re: Hitachi MPI
Hi. I have the same problem with HITACHI MPI ECU ( FIAT COUPE 97 1.8 ).When i try to connect it with 3pin cable program shows me an error. "Error. No ECU response" But when i try to scan. It shows:
Hitachi MPI injection.
ISO Code: 45 85 83 94 B6.
ABS connects ok. Please HELP
Re: Hitachi MPI
In different post yani said:
"I know about this problem and I'm trying to fix it. It happens only with this Hitachi ECU."
So we must wait for next version of FES
Re: Hitachi MPI
Hi!
I have the same problem (Bravo 12.98 1.8 16V). FES try connect via VAG KKL/3pin adapter witch my car but after few second says "Error. No ECU response". Another ECU (ABS/AirBag) is connect witch any problem.
yani - please fix this error
Thx
best regards
Peter
Thx
best regards
Peter
Re: Hitachi MPI
I have the same problem (Barchetta 96), with this message on a modulescan
Engine
Hope there will be a solution soon!
Best regards Martin
Engine
Best regards Martin
Re: Hitachi MPI
Hi guys,
I hate to bring back to life such a long dead thread but I think the internet community of Barchetta owners could benefit from this. I can see that you actually connected to the 96' Barchetta. I have a 95' and have the 4 pin plug near relays in the engine compartment under plastic cover, I saw other owners of B. from 96' had the same: two cases in the internet and one on this forum, the other on the FIAT forum.
Here's how it looks like in my car:
Did your connector look the same? How did you connect to it - did you hand wire it to your 16 pin OBD connector?
