Elm327 always connected
gEnE
Post by gEnE »
Hi guys... i've just purchase a licence of multiecuscan; here my firstquestion:
Can I leave the elm327 cable always connected to the obd port?... I mean, when i finished using multiecuscan and disconnect from usb, it's a problem to leave the obd connector inserted?... just to avoid remove and reconnect the obd each time i want to use the software...
mindstorm
Re: Elm327 always connected
Post by mindstorm »
The OBD connector is always powered by vehicle battery and it's not switched. Your risk is to discharge the battery...
mindstorm wrote:The OBD connector is always powered by vehicle battery and it's not switched. Your risk is to discharge the battery...
I agree with mindstorm
kasiol
Post by kasiol »
hello everone on this board,i am joe and new here. i also use FES to control my 147 jtd powered by squadra tuning. i use a obd2 cable special made for alfa.
a few days ago i bought an elm327 1.4 interface from an friend but the cable was broken. no problem we fixed it. my question is: which is pin 1 on the elm327 board connector?
thanks for a good answer
Joe
kasiol
Post by kasiol »
sorry i forgot to say that the board is like pictures on this forum with inscription USB v.3.0
Regards Joe
