grande punto 1.9 mjet
wilco1v
Post by wilco1v »
today gr punto 1.9 8v mjet
engine not sopprted so i connected 1.3mjet > iso code different of corse ,could read and erase error codes
Can info >>no connection elm327 1,3a+ >test responce elm all ok>
hope send report works (must hope it,s recieved !!!/no feed back???)
Great work Yani
hope next release it,s ok
Fes is great !!!
Re: grande punto 1.9 mjet
You need modified interface or patch cable to connect to Service Reset and Can Info.
wilco1v
Post by wilco1v »
thanx
next time this car is here ill try again
Mazza-Engineering
Post by Mazza-Engineering »
is there a reason, why the 1.9 MJET 8V 130hp ECU in Grande Punto is not listed in the ecu list?
If I connect with 1.3 MJET it can connect but there is no "native" way to connect.
Will there be a update?
Kind regards
