add ecu iaw 6/8/16/18 F
dj_piex
Post by dj_piex »
Please add in the program please read function and the errors of the MIL CANCELLATIONS of Magneti Marelli IAW 6f, 8f, 16f and 18f?
https://www.facebook.com/assistenza.autronica
FES SUPPORTER
ipejasinovic
Re: add ecu iaw 6/8/16/18 F
Post by ipejasinovic »
Currently not possible, because that is an old ECU and uses different type of KL interface and protocols supported in FES.
tzok
Post by tzok »
Not true - as long as interface has two lines (K & L) it can support these ECUs. The problem is that basic VAG interface has in fact only one bidirectional line, but real ISO KL would be enough. For those ECUs we need two unidirectional lines, but it's ok if we have one unidirectional and one bidirectional, or even two bidirectional lines. Electrically - the connection is also compatible with ISO KL interfaces.
jony
Post by jony »
Hí mate , IAW sistem is possible , yet in new version FES.
Thanks.
the_old_lover
Post by the_old_lover »
+1 from me
dj_piex
Post by dj_piex »
hopefully in the future in addition to the communication protocol in iaw then
FES SUPPORTER
+ 1 more request to add ECU IAW 6/8/16/18 F!!! ;)
tzok
Post by tzok »
I also vote for IAW 16F/18F. I can supply a 16F protocol documentation, and I can make a tests on 8F as I've mannaged to get damaged unit and hope I'll be able to make it work. I have other interfaces to test it, so I may compare the results.
ELM327 has two lines and if they could be directly driven (using ELM only as OBD to RS-232 converter), it can be done.
6F and 16F are the same, also 8F and 18F have same protocol, but x6F differ from x8F in meaning of some requests/response formats.
argtv6
Post by argtv6 »
Waiting eagerly too!!
the_old_lover
yani is there any possibility to add these ECU soon?
