BOSCH MONOMOTRINIC MA 1.7.2
Antonio
Post by Antonio »
Hello, I have a Lancia Y10 ( since 1995 ) with Bosch injection MA 1.7.2 but is unknow for the Fiat ECU Scan. Can you help me? You can add in the software my injection? Thank You
Antonio
Re: BOSCH MONOMOTRINIC MA 1.7.2
Post by Antonio »
What can I do?
Antonio
Post by Antonio »
Yani help me :( I have buy the cable but I don't read my injection with current version.
jony
Post by jony »
hí friend , in future version is possible , IAW magneti Marelli group , all ECUs .
This system works with K and L lines , VAG-com interface only .
Yet , in future , FES by YANI is very good program.
Thanks.
+ 1 from me
Antonio
Post by Antonio »
Thank you for answer. So I have to wait a future release, isn't it? I have the correct cable. It works with K and L lines. I miss only the software.
Antonio
Post by Antonio »
Hello are there news about the support of MA 1.7.2? I read that this new year the Fiat Ecu Scan will be improved for MA 1.7.3 support. Will this improvement support also my injection MA 1.7.2?
olahaye74
Post by olahaye74 »
I own an Y10 with the references below, will this new version support Bosch MA1.7 (using ELM327 V1.4a)
I've read that it supports MA1.7.3, but what about MA1.7? is it the same?
Y10 references:
Mode l: Y10 LXie 1.1 litre
Year: 91-95
System: Bosch MA1.7
OE Ref. No.: 0 261 200 716
VM Ref. No.: 7778785
ATP Pt. No.: XEBS0716
Many thanks for your help.
Best regards,
Olivier.
