Punto 2Mk Steering
Punto 2Mk Steering
Is it possible after a steering column change to set the steering balance? as one side is stiff and the other side loose?
Re: Punto 2Mk Steering
on some version you can calibrate the steering system..
connect your pc to the car and check it out by yourself
Well thankyou for the encouragement.
I did try it on a 2001 Mk2 1.2 8v Punto with an 6670 steering ECU and did a calibration and it came out 100% in balance.
What great software.
