I've bought the OBD II cable http://image.made-in-china.com/4f0j00Ue ... e-Tool.jpg,
the device has installed and I can see it on the "ports" on the device manager com8.
I tried to run the test on the setting form, and get the messege on the subject all the time.
what am I doing worng ?
the operaton has timed out
Re: the operaton has timed out
I have bought the same product, from an english ebayer and I have the same problem.
Maybe the ELM that we bought is fake?
I have bought the same elm 327 and have the same problem.
Can you help us...
Can you help us...
I don't have this problem anymore. after few times I've understand what I did wrong.
My cable is OK
My cable is OK
Can you explain what did you do wrong when you have the message "the operation has timed out".
Thanks for your help.
The cable should work! You just need to install all the drivers and change (or find/ edit) the com port # and that is it! Maybe you need to restart you laptop and it should work!
I got the same cable, v1.4a, and it is working!
try to connect interface with the car and you should NOT get this message any more!gbbt wrote:Hi,
You're right
Thanks alfa156sarajevo
