Export to CSV
TribesMan
Export to CSV
Post by TribesMan »
Hi, I've just tested this software and it is GREAT!
But there is one little thing that bothers me. When you export the logged ECU parametres into CSV file, you use comma (,) as a seperator for different values. But You also use comma as a decimal separator. And this is a bit annoying and confusing, and it makes it harder to use and work with the data in Excel.
This is the way it looks when you open the file:
Engine Speed,"Desired Intake Air Quantity","Intake Air Quantity","Battery Voltage","Gas Pedal Position"
rpm,"mg/i","mg/i","V","%"
0,0000,411,3000,0,0000,12,0624,0,0000
Is there any option to use semicolon (;) as a separator for different values (that would be prefered)? Or a dot instead of a comma as a decimal separator?
To make it look like this:
Engine Speed;"Desired Intake Air Quantity";"Intake Air Quantity";"Battery Voltage";"Gas Pedal Position"
rpm;"mg/i";"mg/i";"V";"%"
0,0000;411,3000;0,0000;12,0624;0,0000
That would make the it much easier to work with the logged data.
Thanks, and keep up the good work!
kecka
Re: Export to CSV
Post by kecka »
Yes. would be good for the individual data were divided by columns. It would be better to do chart ....
Thanks ;) ;)
Re: Export to CSV
Ok, no problem.
You get comma as a decimal separator because your system is configured that way. I never use comma as decimal separator on my computers, but that is a matter of personal preference.
Anyway, I'll fix the column separator in the next release to be ";".
TribesMan
Re: Export to CSV
Post by TribesMan »
Thanks! I'm looking forward for next release...
