Marea 97 and 98 1F2P airbag connection
spike
Post by spike »
Hi Yani,
I cannot connect to the above. I can connect fine to the 99 2F2P airbag with my cable. Is the older one not supported or do I need to make an adjustment in my settings. Help appreciated. I like the software. Thank you.
Re: Marea 97 and 98 1F2P airbag connection
As far as I know in MAREA are installed the following airbags:
- Allied Signal
- ALLIED MY 97
- BREED MY 97
MY97 airbags are supported by Multiecuscan, but Allied Signal is not supported. I don't know when I will be able to support it, and if I will support it at all because it uses an older communication protocol.
psf
Post by psf »
hi, yani I want you to know that waiting for support on AUTOLIV airbag on lancia ypsilon I TRIED (I SHOULDN'T DO IT) I selected anyway with this car (and other) the TRW MY97 and even BREED. SO IT access to ECU and it indicated some errors (they should be right) I dont know but they seem right because it's a rare error on front crash sensor (open circuit). If you want I can send you the screenshoot...I don't reset anything because I think I'll make mistake..THANKS BYE
