Interface autoselection
seth
Post by seth »
In last time I had to do some things in BC and ABS. Manual switching between ELM and VAG in Settings was a little annoying.
So i have an idea. It needs from FES to be smart and know to which module what interface is needed (it is no difficult to implement). User should set ONCE ports for ELM and VAG and in case of using ELM which type will be used (Bluetooth or normal cable). After that FES will automatically check which interface is needed and get a port from Settings.
Yani, what do you think about that?
Re: Interface autoselection
Sounds like a good idea.
I will add this feature to my TO DO list.
Thanks,
