Screwed my Fiat 500L
abarthmultijet
Re: Screwed my Fiat 500L
Can you try this one?:
33 31 33 33 30 30 31 30 38 34 38 4F 55 54 50 55 54 2D 53 49 54 20 17 10 20 4F 04 00 05 10 00 00 00 09 04 00 05 10 00 00 00 07 C2 71 07 85 00 37 00 30 00 44 06 00 07 08 8C 03 15 01 28 C2 00 D1 01 35 41 0A 0C 0D 00 80 3E 58 00 02 00 00 32 00 29 03 00 11 16 00 A0 20 05 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 9E 00 01 08 02 00 04 80 10 00 10 80 00 00 40 00 81 00 11 00 00 49 00 01 14 40 00 00 00 00 00 00 00 20 00 00 00 00 00 00 00 05 00 00 00 00 00 00 00 00 01 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
I tried. No errors, no CarPlay nor android auto. If I Connect my iPhone with usb, it takes me (on the phone) to configure CarPlay), but i only get connection like if it is an ipod. Looks like something regarding usb module configuration?abarthmultijet wrote: ↑12 Feb 2025, 21:29 Can you try this one?:
I also have a Otto u2 play (for wireless CarPlay), if I Connect it and try to go to Bluetooth options on the radio, i see intermitent info that CarPlay is working.
abarthmultijet
Can you upload an photo of what you see on phone?
If I forget all devices, when I connect the phone to the radio (usb) i see the CarPlay logo. After that, I see nothing (only charging and Apple Music opened).
On my radio I see this intermittent. (IMG_3507, last photo). Left side options, the 4th one, also intermittent,
I also send more photos (multiecuscan).
- IMG_3505.jpeg (2.27 MiB) Viewed 17589 times
- IMG_3504.jpeg (3.33 MiB) Viewed 17589 times
- IMG_3507.jpeg (1.18 MiB) Viewed 17589 times
- IMG_3504.jpeg (3.15 MiB) Viewed 17112 times
- IMG_3505.jpeg (2.17 MiB) Viewed 17112 times
- IMG_3506.jpeg (3.58 MiB) Viewed 17112 times
abarthmultijet
Do you use body computer 2019? If so, can you try the other without a year.
I use it both (not to upload the last one you gave me). I Will do it. Will report it after.abarthmultijet wrote: ↑15 Feb 2025, 10:46 Do you use body computer 2019? If so, can you try the other without a year.
I tried it. Still no CarPlay, same things… but i have an error (time out error on IPC/NQS FAILED! Timeout error.abarthmultijet wrote: ↑15 Feb 2025, 10:46 Do you use body computer 2019? If so, can you try the other without a year.
Radio does not reboot when i do this.
- IMG_3520.jpeg (2.82 MiB) Viewed 16888 times
Edit: i enabled aux and GPS… CarPlay and Android auto is working. I gess the problem was aux disabled. Thank you for your help!Koplinjp wrote: ↑15 Feb 2025, 15:12I tried it. Still no CarPlay, same things… but i have an error (time out error on IPC/NQS FAILED! Timeout error.abarthmultijet wrote: ↑15 Feb 2025, 10:46 Do you use body computer 2019? If so, can you try the other without a year.
abarthmultijet
With what proxy code and with 2019 selected or no year?
