Fiat 500 2018 with ecu 9gf. Car start and cut after few seconds
didi_du_93000
Hi I have a Fiat 500 from 2018. It starts and for 5 seconds and stop. if I hold the accelerator it stays started for about 20 seconds. I put back a blank calculator which was autocode and I have same problem.
Any anyone know the problem?
Thanks in advance.
Thanks in advance.
abarthmultijet
Re: Fiat 500 2018 with ecu 9gf. Car start and cut after few seconds
Any fault codes stored?
didi_du_93000
Problem solved, an massa broken in car.
It's back from thief. So we have changed the BCM with second hand because original is missing.
I have virgin ECU motor, adapter to car.
Now i have mil blinking in dashboard due to proxy aligment. I have do it but i have always error on the ETM (entertainment telematic node).
How can i do to make working?
Regards,
Regards,
- 20241205_145746.jpg (4.93 MiB) Viewed 16101 times
- 20241126_162455.jpg (4.11 MiB) Viewed 16101 times
abarthmultijet
You can obtain the original radio code via the interweb, quite a few websites who do radio codes.
Can you upload the current proxy?
didi_du_93000
I have pin code of the radio.
I have changed the bsi.
This is the log and hex proxi backup.
FESLog_2411261617_Fiat 500 1.2 8V.txt- (1.6 KiB) Downloaded 421 times
abarthmultijet
Only error with ETM when doing allignment?
didi_du_93000
abarthmultijet
And any fault codes in ETM?
didi_du_93000
Thanks for all help.
Car startnow.
I have make some reset on ecu.
About proxy bytes. I have copy an proxy bytes from a thread on forum and now all work good now.
Car startnow.
