500X - Comfort seats
Adam__CZE
Post by Adam__CZE »
Good day,
I bought new seats for the 500X. Unfortunately, they are electrically adjustable and have heating. The car originally had manual seats and no heating.
I installed everything in the car according to the original diagram. I added it to the CAN network using diagnostics, but the body computer cannot control the heating and give a signal to switch on the relay for moving the seats. Diagnostics does not see any error. Proxy configuration cannot be done through the original diagnostics. Kilometers flash after connecting the seats. I would like to ask if anyone knows in which bytes of the proxy code at least the heating of the seats is encoded. I have a proxy code from a car that has, at least only a warm-up. As for the drive, a positive contact can be made by turning on the key to switch on the relay.
It would help me a lot.
rosnik
Re: 500X - Comfort seats
Post by rosnik »
I replaced my seats with full electric adjustable positioning seats, not heating .
I simply pluged the seat plugs in the, already wired, plugs under the seats and added the fuse in the Fuse position.
No need of diagnostic or flashes appened.
I suggest you to se if you got heatting brain under the passenger seat , under the carpet
