Supprimer la Fonction Coasting Alfa Stelvio 2.2D 210cv
Pat08
Post by Pat08 »
Bonjour, je souhaite supprimer la fonction Coasting (passage en roue libre de la transmission) mais je ne trouve pas le paramétre? Si quelqu'un peut m'aider, merci d'avance.
Edited by moderator: Please try to post in English or supply a translation as well unless there is a section for your language. This helps people respond and not ignore your post!
Hello, I want to remove the Coasting function but I can't find the setting? If anyone can help me, thanks in advance.
Pat08
Re: Supprimer la Fonction Coasting Alfa Stelvio 2.2D 210cv
Post by Pat08 »
Hello, I would like to remove the Coasting function (freewheeling of the transmission) but I cannot find the setting? If anyone can help me, thanks in advance.
BBOinsam
Post by BBOinsam »
In it something is. Clearly, thanks for the help in this question.
