Hello everyone!
I recently had a friend come to me for a Cruise control activation on a Fiat tipo 2018 1.4.. The car came without one and he put a second hand steering wheel with buttons and wiring. The problem is that i activate the option with MES but it stil doesn't work. The CC buttons on the steering wheel light up for a few seconds when putting The ignition in ON position, then they go off.
Also, i get proxy allignment errors for the airbag node NAB ORC Request put of range error.
Anybody know how can i work this through?
Fiat tipo 2018 Cruise control retrofit
Re: Fiat tipo 2018 Cruise control retrofit
Had a similar problem when I send my ecu out to get remapped. I could activate it with ignition on and the screen said: Cruise control activated.
Send the ecu back to them and they fixed it right away. I think your engine ecu needs to be programmed also.
HI!
Bodycomputer on Fiat Tipo signed with L0 does not support cuise control!
If you want CC just swap BCM with L1 or L2
