knock control not showing correctly
yoko
Post by yoko »
since i started using MES and even before when it was FES
my car Fiat linea 2009 i used to get logs for it and specially knock control and it always shows off in the graph and i had blown my engine twice due to knocking :(
i just found few days ago that in the csv file it shows that there is knocking but the graph always shows off
https://i.postimg.cc/BvHNJSH9/1.png
https://i.postimg.cc/NMtDM3ky/2.png
also spark advance and injection timing always read 0
yoko
Re: knock control not showing correctly
Post by yoko »
any help?
Dihofma
Post by Dihofma »
just reading your article and it seems to be, that I have a similar issue. Can you check in the ECU Parameter if Knocking Control is enabled ? Mine is not active and I’m wondering why this important feature seems to be disabled. It looks like, that there isn’t any option to enable it ( ECU proxy alignment ).
Is there a list available what's showing the Hex values of the functionality what can be changed/adjusted?
Dirk
