Fiat Ducato Clutch Calibration
Knotty
Post by Knotty »
I'm trying to perform a clutch calibration on a Fiat Ducato with a Comfortmatic gearbox.
I've also tried to perform a clutch drain (clutch bleed).
The clutch bleed fails with a critical software error.
The clutch calibration just drops out without processing.
There is an error code that I cannot clear, I assume I need to complete a calibration to remove the error code.
Anybody have any ideas of how to fix or get around these problems?
Is it something I'm doing wrong?
Any help or guidance would be appreciated.
Log details:
(Multiecuscan 5.1)
15/05/2023 14:46:04
Fiat Ducato (type 290) 2.3 Multijet
Marelli SELESPEED CFC448F Automatic Gearbox
ECU ISO code:
VIN code:
FIAT drawing number: 55279815
Hardware number: CFC 448F.06
Hardware version: 00
Software number: FEA09FAT
Software version: 0000
Homologation number:
Functioning time (EEPROM): 214
Operating time: 214
READING ERROR CODES:
1. P290E-55 - Clutch self-calibration enable
ERROR DETAILS:
Operating time: 54803 min
Engine speed: 0 rpm
Hydraulic circuit pressure: 43 bar
Gearbox oil temperature: 14 °C
Gear requested: N
Gear engaged: N
Battery voltage: 11.9 V
EXECUTING ADJUSTMENT...
indeuro
Re: Fiat Ducato Clutch Calibration
Post by indeuro »
I had the exact same problem,,,, did everything I know to get around this problem,,, in the end fitted a new Bosch battery and wham, everything worked.
