Mood selector 500x not working
500xconnect
Post by 500xconnect »
Tried to activate mood selector in 500x 1.4 turbo gpl, alignment is ok, but nothing happens. Yani could you check? Maybe it need manual bytes modification. Thanks.
500xfiat
Re: Selettore dell'umore 500x non funzionante
Post by 500xfiat »
Hi, you managed to enable mood selector. I'm told Yani knows the bytes to change. I also have the same 500x model. Thank you
gcelettronica
Re: Mood selector 500x not working
Post by gcelettronica »
hi friend i need this byte can you help me for mod selector ?
chrener
Post by chrener »
I am really very surprised on you guys...
You tried to do retrofits without any experiences...
It is really not about asking on forum...
What did you do with mood selector?
Was connector prepared or did you add wirings? Which scheme did you use?
Do you know correct bytes settings?
Which type of car do you have? And which type of selector do you need to add and coding?
Because there are lots of differents...
