budgoz
Post by budgoz »
Bobwilson76 wrote: 04 Mar 2023, 21:23 I don't need the Arbarth version on mine, just the 500T, I was just hoping to be able to switch between them to see which options it gave me.
I'll note the btyes down and post it up later this evening.
Send me your proxy and I'll look into it
Bobwilson76
Post by Bobwilson76 »
Sorry about the delay, here's the proxy code from our 2011 Twin Air before I swapped the TFT screen.
33 32 31 35 30 30 30 34 37 34 37 4F 55 54 50 55 54 2D 4A 49 54 20 10
23 digits in row 1-23
09 29 6F 04 00 04 02 00 00 00 09 00 00 04 02 00 00 00 12 C0 71 06 F4
23 digits in row 24-46
00 17 20 AA 80 00 06 00 01 00 94 06 01 01 00 00 00 00 00 7A 41 0A 0C
23 digits in row 47-69
0D 00 00 00 23 00 00 00 00 11 05 61 00 08 00 00
16 digits in row 70-85
Cheers Bob
JMM
Post by JMM »
Hi everybody,
As many of you, I swapped my Uconnect 5 by a Uconnect 7 DAB Nav Carplay and obviously I encountered some problems to register my fine new radio.
I have a FIAT 500 1.2 8V car built in 2017 and registered by FIAT with a Uconnect 5.
I use MES 5.1 to do a proxy Alignment Procedure (2014+) to register identify my Uconnect 7 but it's a failure :( I got the famous message: "Entertainment Telematic Node (ETM) EOL failes
As error code I get:
- Uconnect radio/Nav 7"
- Code ISO 00 24 70 55 15
- Failure
- Errors found
B222C-00
My diagnostic report is
33 32 31 35 30 30 32 33 34 37 37 4F 55 54 50 55 54 44 4A 49 54 20 16 11 22
4F 80 00 05 10 00 00 00 09 00 00 04 10 00 00 00 81 C2 73 06 F4 00 1C C0 00
00 00 16 00 01 00 94 06 41 01 00 40 00 00 00 75 41 0A 0C 0D 01 80 2E 24 00
00 00 00 31 05 11 03 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 47 00 94 08 52 00 04 88 02 00 20 80 00 00 40 00 81 00 0F
00 00 00 00 01 00 C0 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Body Computer (BCM/NBC)
Contrôle Moteur (ECM/NCM)
D.A. électrique (EPS/NGE)
Tableau bord (IPC/NQS)
Dispositif de freinage (ABS/BSM/NFR)
Noeud Embardée/Accélérat. Latérale (NYL)
Noeud Capteur Stationnement (PAM/NSP)
Noeud Air Bag (NAB/ORC)
(Multiecuscan 5.1)
21/03/2023 18:26:06
Fiat 500 1.2 8V
Body Computer (BCM/NBC) EOL Ok
Contrôle Moteur (ECM/NCM) Ok
D.A. électrique (EPS/NGE) Ok
Tableau bord (IPC/NQS) EOL Ok
Dispositif de freinage (ABS/BSM/NFR) Ok
Noeud Embardée/Accélérat. Latérale (NYL) Ok
Noeud Capteur Stationnement (PAM/NSP) Ok
Noeud Air Bag (NAB/ORC) EOL Ok
Entertainment Telematic Node (ETM) EOL Failed
I read different discussions and I understand that's necessary to modify or add som Bytes to do a well done modification but my knowledge gets some limit.
My purpose is to get again my wheel functions, to avoid my mileage flashing and to get benefit of my new Uconnect 7 with all the advantages for which reasons I bought it
Hope that one of you will help me, many thanks for it. :shock:
kanada_green
Post by kanada_green »
Hi Everyone! I'm new here, but I have a few questions.
I have purchased an ABARTH 595 LHD which was originally and officially imported to Japan,
I have brought it to EU and have a few things that really bug me about the radio.
1) The FM only goes up to 95.0
2) there are NO radio station names, only the digits
3) I don't have DRL in the menu
4) In the Engineering menu it says that I have GPS signal, but there is NO Navi button
5) There are only English and Japanese languages
Can someone please help me to get everything functioning the way it supposed to.
Also how can I tell what kind of Uconnect7 I have (navi+dab or what)
chrener
Post by chrener »
JMM wrote: 22 Mar 2023, 17:44 Hi everybody,
- Failure
- Errors found
B222C-00
(Multiecuscan 5.1)
21/03/2023 18:26:06
Fiat 500 1.2 8V
Hi!
Extend your proxi up to 250 bytes and run proxialignment
chrener
Post by chrener »
kanada_green wrote: 23 Mar 2023, 14:43 Hi Everyone! I'm new here, but I have a few questions.
change country in proxi to italian or any european country
set also drl menu to enable, nav to enable etc and run proxialignment procedure...
if you want to know what your radio supports so dissasemble it and read from top label...
Radio can be GPS type with compass only without navigation
for navi you have to see NAV on it
kanada_green
chrener wrote: 24 Mar 2023, 09:08
only by dissassembly i can tell if it's navi?
JMM
Post by JMM »
chrener wrote: 24 Mar 2023, 09:02
- Failure
- Errors found
B222C-00
(Multiecuscan 5.1)
21/03/2023 18:26:06
Fiat 500 1.2 8V
Hi!
Hi Thks for your reply, I will try this WE :)
Sotiris76
Post by Sotiris76 »
I’m new here and I’m from Germany. I have a little problem and I need some support. I changed my uconnect 5 to uconnect 7. Since I changed it, it shows the following error :
Knoten Airbag (NAB/ORC) EOL Fehler
I have an abarth 595 competition manual (2016)
Below you will find my
custom PROXI:
33 32 31 35 30 30 31 39 38 31 39 4F 55 54 50 55 54 44 4А 49 54 20 16 07 01 4F 84 00 05 10 00 00 00 09 00 00 04 10 00 00 00 81 C2 75 06 FE 00 1C CO 00 00 00 16 00 01 00 94 06 01 01 00 40 00 00 20 75 40 0A 04 00 01 80 2E 24 00 00 00 00 31 02 51 00 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 BB 00 94 08 52 00 04 88 02 00 20 80 00 00 40 00 D7 00 OF 00 00 00 80 05 00 C0 02 00 00 00 00 00 80 00 00 00 00 00 00 00 00 05 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Thank you very much in advance!
JMM
Post by JMM »
Hi everybody,
I connected my new Uconnect 7 instead of my previous radio Uconnect 5
The problem that I, it's impossible to get Carplay, evrything work well, it's a new Uconnect 7 working well (Except for my Fiat 500 1.2 8V :evil: ) with DAB Touch CARPLAY 2020 when I bought it in Italy.
I tried many tests but without success.
Please find herewith my proxy report:
00 00 00 00 00 00 47 00 94 08 52 00 04 88 02 00 20 80 00 00 40 00 05 00 0F
00 00 00 00 01 00 C0 01 00 00 00 00 00 80 00 00 00 00 00 00 00 00 05 00 00
00 00 00 00 00 00 01 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 80
(Multiecuscan 5.1)
27/03/2023 15:01:15
Fiat 500 1.2 8V
Entertainment Telematic Node (ETM) EOL Ok
ATTENTION Ce véhicule est correctement configuré. L’alignement PROXI n'est pas nécessaire
Regarding this proxy, somebody may help me to resolve this problem : No Carplay activate
Many for your help :P
