I installed an android unit in my Fiat Bravo 2 vehicle. and i had km flashing problem.
I wanted to connect with my Bluetooth Pic18F25K80 ELM apparatus using multiecuscan and set up a proxy.
(By the way, I can delete error codes etc.)
but when I start proxy setting, even though writing to all modules is successful
Writing to module: Failed to connect instrument cluster (IPC/NQS)! - Timeout Error
I get this error. and my odometer is not improving.
I chose the slow connection option.
ELM Device I Use:
https://i.snipboard.io/s64zWU.jpg
The Error Report I Got:
<CODE><s>
</s>Reading CAN configuration...
CAN CONFIGURATION DATA:
05 00 84 EF 05 00 84 EF 00 00 04 45 00 00 04 01 00 00 00 00
05 00 84 EF 04 00 04 89 05 00 84 EF 04 00 04 89 04 00 04 A9
30 34 31 39 38 30 30 39 36 30 33 4F 55 54 50 55 54 2D 4A 49 54 20 09 07 29 EF 84 00 05 89 04 00 04 81 01 00 07 8F 28 16 00 00 02 84 06 01 3C 01 2E 00 81 00 53 00 24 00 00 00 00 00 00 00 00 76 41 05 0C 01 00 00 00 3A 20 A8 80 00
(BCM/NBC) Body Computer
Engine control point (ECM/NCM)
(EPS/NGE) Electric power steering
Instrument cluster (IPC/NQS) connection
Radio/Mapped radio navigator (NRR/RMN)
(ABS/BSM/NFR) Brake system point
Info-Telematics/Balance point (NIT/NCV)
(HVAC/NCL) Climate control point
Side Acceleration/Yaw point (NYL)
Parking Sensor Point (PAM/NSP)
(NAB/ORC) Airbag Point
(Multiecuscan 4.8)
15.03.2023 23:02:07
Fiat Bravo '07 1.4 Turbo 16V
(BCM/NBC) Body Computer: EOL Ok
Engine checkpoint (ECM/NCM): Arrow
(EPS/NGE) Electric steering: Arrow
Instrument cluster (IPC/NQS) connection: EOL Ok
Radio/Mapped radio navigator (NRR/RMN): Arrow
(ABS/BSM/NFR) Brake system point: Arrow
Info-Telematics/Balance point (NIT/NCV): EOL Arrow
(HVAC/NCL) Climate control point: EOL Ok
Side Acceleration/Yaw point (NYL): Arrow
Parking Sensor Point (PAM/NSP): Arrow
(NAB/ORC) Airbag Point: EOL Arrow
SETTING UP...
PROXI EDIT PROCEDURE
Writing CAN configuration data...
Writing to module: (BCM/NBC) Body Computer SUCCESSFUL!
Writing to module: Info-Telematics/Balance point (NIT/NCV) SUCCESSFUL!
Writing to module: (HVAC/NCL) Climate control point SUCCEED!
Writing to module: (NAB/ORC) Airbag Point SUCCESSFUL!
RUN FAILED
Failed to connect instrument cluster (IPC/NQS)! - Timeout Error<e>
