OBD II Scan tool bluetooth and this multiecuscan
Zwiebel
Post by Zwiebel »
Hi!
I'm new in this program use. I have 1 cable OBD II scanner, and 1 bluetooth OBD scanner. I want to use them, but with this program, only the cable scanner is good. When I connect the bluetooth to my computer, everything is good, but when I'm go to the program and want to connect, I have an error message, with timeout. I tried every speed, and COM. My program write in settings to test, Command: ATZ and error here too... Please, if you can, help for me :cry:
EnIgMa
Re: OBD II Scan tool bluetooth and this multiecuscan
Post by EnIgMa »
does windows recognize it?
can you view a kind of bluetooth devices list?
if yes, check the com port and speed, THEN try to use it with fiat ecu scan...
what's your OS?
Zwiebel
Post by Zwiebel »
I use XP with Service Pack 3. I see the OBD in my bluetooth devices, and it's write connected. I tried COM6 and COM7 Port with all speeds, but at the Test function it writes error too.
DeXa
Post by DeXa »
I am also having problems connecting with Bluetooth ELM327 v 1.3a. I get timeout errors. I have tested all sort of settings with no luck at all. When I use hyper terminal or putty to open the comport directly everything is fine and I have no timeouts and disconnects I am able to send commands to the interface but with FES I can't.
EnIgMa
Post by EnIgMa »
taht's strange,,,did you guys try a previous version?
