I have problem with ECU read with my 2017 Fiat 500 1.4 Multiair + automatic transmission (US market).
Engine: (ECU) / ECM
UNKNOWN / UNSUPPORTED
CODE ISO: 34 90 10 0D 26
CODE VIN: XXXXXXXXXXXXXXXX
HARDWARE NUMBER: MM8GMKHW666 - VER:00
SOFTWARE NUMBER: 05300000 - VER: 0530
Other modules reading fine. Any ideas?
2017 Fiat 500 USA 1.4 Multiair ECU Unknown/Unsupported
Re: 2017 Fiat 500 USA 1.4 Multiair ECU Unknown/Unsupported
Each ECU/Control unit has to be coded by the developer and as there are very many different types and variations not all are supported. Put a request into the Feature Requests thread and add the ISO etc. information.
That said you will probably still be able to connect to the ECU and do and read basic common things.
Hi,s130 wrote: ↑25 Mar 2022, 07:40 Each ECU/Control unit has to be coded by the developer and as there are very many different types and variations not all are supported. Put a request into the Feature Requests thread and add the ISO etc. information.
I have the same issue with the BCM in a North American 2014 Fiat 500 Abarth.
UNKNOWN/UNSUPPORTED
ISO Code: 40 83 6B 8A 0D
VIN code: XXXXXXXXXXXXXXXXX
Hardware number: P500L1EU304 - Ver: 03
Software number: 28427037 - Ver: 0503
I'll try putting a request in the Feature Request as you suggested.
