INTERFACE TYPE REQUIRED FOR EACH MODULE!!!
AntoninoPizzonia
Re: INTERFACE TYPE REQUIRED FOR EACH MODULE!!!
Post by AntoninoPizzonia »
Ciao Yani ho problemi con il connettore numero 5 vorrei entrare nel setup dell'uconnect ma non me lo riconosce ti premetto che sto parlando della fiat freemont e per quanto riguarda il connettore 5 cioè il blu ho seguito passo passo le tue istruzioni puoi aiutarmi grazie
smiley1081
Post by smiley1081 »
quite new around here...
So, I need to check the ABS on my '99 Punto 1.9 JTD to see why it sometimes work and sometime it does not.
The blokes at the local FIAT shop were not able to check it, even with an official FIAT interface.
I gather that If I buy your CANtieCAR interface I do not need anything else, (except for a PC to connect), as it should autoconfigure the connection to mimic the A1 cable, am I correct?
Where may I find more in depth info on how to use it, so that I can start to study?
Then I will have to wait two week to order it...
McLovin
Post by McLovin »
Still not clear to me, how to understand http://www.multiecuscan.net/SupportedVehiclesList.aspx
I have a 2005 Fiat Stilo 1.9 Multijet 88kW.
Lets say, i will buy an ELM interface like:
https://electronic-fuchs.de/epages/e87b02f8-46da-4792-be6d-42392d89d882.sf/de_DE/?ObjectPath=/Shops/e87b02f8-46da-4792-be6d-42392d89d882/Products/1000-7-%280%2C1kg%29
Then I would have access to all modules without any adapter except Airbag.
Airbag needs an KKL interface, right?
Or each line is an 'AND', and it would be required for Airbag KKL, red adapter and Pin 3 (for interfaces with pin switch)?
Thank you
Post by s130 »
Each line by module lists:
1) Interfaces that can be used: So if ONLY KKL is listed then a KKL interface is the only one that will work. If KKL and ELM is listed then either should work.
2) Adaptors required: These are in addition to an interface device. So KL, ELM, A1 means yout need a KKL interface with adaptor A1 OR and ELM interface with adaptor A1
3) Pins used if not standard: P9 means the data connection is done on Pin 9. So a listed interface has to talk to Pin 9. This is what the adaptor A1 does. The P9 is listed because some people uses switches or patch boxes as opposed to buying all the possibly required adapters
BBOinsam
Post by BBOinsam »
I removed and then re-added as root, didnt help, still get those same errors with runsvdir.
Heres the ls for the mythexport service scripts
Code:
SATAN78
Post by SATAN78 »
bom dia tenho a versão multieuscan 5.2 e comprei o vLinker MS e nao consigo conectar ??? (fiat 500 1.2) alguma ajuda Obrigado
