Hi, I wanted to know how to reset the service of fiat stilo 1.9 jtd 2003.I state that I have an ELM327 compatible cable (with PIC and FTDI chip inside) that is easily recognized.I modified the cable with the union pins 1-7-9, and I OK connect to the engine control units, ABS, steering.When I try to connect to the service, with baud rate of 9600, the program gives me connection timeout error. If i increase the baud rate to 38400, the program returns me error ELM327-> ECU not connect, check the cable.
Can someone help me solve this problem? Thank you all.
Fiat Stilo Service reset
Re: Fiat Stilo Service reset
The problem seems to be in the ELM interface. It is either old version or faulty.
As you know, I have exactly the same problem.
Which ELM interface is recommended? If I search in the net, I get a lot of Chinese products.. but I still have 2 and don't want to spend more money to Chinese stuff.
Can you recommend a payable one?
Regards
Kay
Regards
Kay
Hi Yani, thx for your job, my interface is the second picture in the section "How to use" the green and blue.
I was recognized as ELM327 v1.3. Do you have other suggestions?
Your interface is probably faulty.
My interface (from that picture) is also faulty. It has a proper ELM 1.3a inside, but cannot connect to CAN. Another user with the same interface and the same problem reported that he has fixed his interface by changing 2 capacitors inside.
Just try with another ELM interface.
I would be interested in this too..
