Particle filter status, gen. error
sanscorp
Post by sanscorp »
When I try to read the particle filter status on my AR Giulietta 2.0 JTDm2 from 08/2015 (euro 6, edc17c69) I get gen. error
I guess generic error?
No fault codes, no clogged filter (varies from 30 to 100 percent) and regenerations are regular.
The help window in MES tells me there are 8 status options but gen. error isn't one of them.
Is this feature/data just not supported/available?
I noticed some parameters, adjustments or actuators, don't show data or always immidiatly give an execution error, like Low pressure egr (valve test) for example.
3rd fan speed is another. Won't execute.
Some info on what value's should be would also be very nice. It's a tool for enthousiasts and sometimes refommended value's (or "should be between") are shown in the help section.
Problem I'm experiencing, that made me search for more data, is that the engine idle is irregular at an almost cold engine and sometimes stutters while driving. Holding back shortly.
I'm suspecting firmware update, malfunctioning throttle body or egr. But again, no errors..
Thanks!
Thank you in advance.
