S/N 03323
Supplier 96848
Date 27/03/2018
FCA PN07356831240
SW-version 22.00.63.01
HW-version F.EU.D5.V25
A2C131000300017345
Traceability 07356831240968480332308518
FCC ID:Y70VP2RFP
IC:781 2H-VP2RFP
This is all numbers
Uconnect/ecodrive
Re: Uconnect/ecodrive
Hi @Malse,
Could you please share the custom proxi configuration with me? I've got a 7' uconnect radio in Tipo with Nav/Dab support but it's not activated. You mentioned Yanislav sent to you.
Uconnect is paired not with the cars VIN number but with the radios serial number. To get uconnect live working again you need to contact uconnect support.
Did ecodrive start working for you? I have so many problems with getting ecodrive and carplay to work...
Hoping for some advice, we have. 2017 500 with the 5in DAB uconnect head unit. I brought a 2019 7in uconnect with DAB and Nav and was wondering if I needed a radio code (seller didn't mentioning needing one) and also once I fit this head unit will I need anything else.... I don't plan on using sat nav or connect live as I was to use the apple carplay feature.
Many thanks in advance
Could you also help with code for A3C003356000100002921 from ZFA3340000P723915?
Did you get it working ? Have proxi details that may help.DGinUK wrote: ↑29 Mar 2020, 13:50 Hi
